Motor commands list v2.1
The command ids used by the commander interface are defined in the library source by the default values in the header file: src/communication/commands.h, here is the list of the commands:
// list of commands
#define CMD_C_D_PID 'D' //!< current d PID & LPF
#define CMD_C_Q_PID 'Q' //!< current d PID & LPF
#define CMD_V_PID 'V' //!< velocity PID & LPF
#define CMD_A_PID 'A' //!< angle PID & LPF
#define CMD_STATUS 'E' //!< motor status enable/disable
#define CMD_LIMITS 'L' //!< limits current/voltage/velocity
#define CMD_MOTION_TYPE 'C' //!< motion control type
#define CMD_TORQUE_TYPE 'T' //!< torque control type
#define CMD_SENSOR 'S' //!< sensor offsets
#define CMD_MONITOR 'M' //!< monitoring
#define CMD_RESIST 'R' //!< motor phase resistance
// commander configuration
#define CMD_SCAN '?' //!< command scaning the network - only for commander
#define CMD_VERBOSE '@' //!< command setting output mode - only for commander
#define CMD_DECIMAL '#' //!< command setting decimal places - only for commander
// subcomands
//pid - lpf
#define SCMD_PID_P 'P' //!< PID gain P
#define SCMD_PID_I 'I' //!< PID gain I
#define SCMD_PID_D 'D' //!< PID gain D
#define SCMD_PID_RAMP 'R' //!< PID ramp
#define SCMD_PID_LIM 'L' //!< PID limit
#define SCMD_LPF_TF 'F' //!< LPF time constant
// limits
#define SCMD_LIM_CURR 'C' //!< Limit current
#define SCMD_LIM_VOLT 'U' //!< Limit voltage
#define SCMD_LIM_VEL 'V' //!< Limit velocity
//sensor
#define SCMD_SENS_MECH_OFFSET 'M' //!< Sensor offset
#define SCMD_SENS_ELEC_OFFSET 'E' //!< Sensor electrical zero offset
// monitoring
#define SCMD_DOWNSAMPLE 'D' //!< Monitoring downsample value
#define SCMD_CLEAR 'C' //!< Clear all monitored variables
#define SCMD_GET 'G' //!< Get variable only one value
#define SCMD_SET 'S' //!< Set variables to be monitored
By modifying this header file you can modify the default command character for the whole library.
