Implementing a custom sensor
GenericSensor is a new class of the SimpleFOClibrary that simplifies the implementation of new sensors. With this class you are able to add a custom sensor to your code and link it to the motor in one arduino file.
Step 1. Implement the function reading your sensor
Basically all that you need to do in your arduino code is implement a function that reads your sensor and returns an angle in radians between 0 and 2π:
float readMySensorCallback(){
// read my sensor
// return the angle value in radians in between 0 and 2PI
return ...;
additionally you can optionally implement a function that initialises your sensor
void initMySensorCallback(){
// do the init
Step 2. Instantiate GenericSensor class
To initialize the sensor class you need to provide it the pointer to your function reading the sensor, and optionally the pointer to the function that initialises your sensor.
// GenericSensor class constructor
// - readCallback pointer to the function reading the sensor angle
// - initCallback pointer to the function initialising the sensor (optional)
GenericSensor sensor = GenericSensor(readMySensorCallback, initMySensorCallback);
Step 3. Using your sensor in real-time
There are two ways to use sensors implemented within this library:
You can use your sensor as a standalone sensor. To get the sensor angle and velocity at any given time you can use the public methods:
class GenericSensor{
Calling
Here is a quick example:
// read my sensor
return ...;
// do the init
// create the sensor
// initialize sensor hardware
Serial.println("My sensor ready");
// update the sensor values
To use the sensor with the foc algorithm implemented in this library, once when you have initialized sensor.init(), you just have to link it to the BLDC motor by executing:
So in general your code will look something like this:
// read my sensor
return ...;
// do the init
BLDCMotor motor = ....
// link to the motor
New sensor support full example - ESP32 hardware encoder
Here is an example code implementing a hardware counter based encoder implementation based on the ESP32 architecture that the SimpleFOClibrary doesn’t support by default. To setup the counters and all the hardware parameters here we use the library ESP32Encoder and the full code of the example is as follows:
#include <ESP32Encoder.h>
// create the ESP32Encoder class
ESP32Encoder encoder;
// define the sensor cpr (500x4)
int64_t cpr = 2000;
// function intialising the sensor
// use pin 25 and 26 (Arduino pins 2,3) for the encoder
encoder.attachFullQuad(25, 26);
// function reading the encoder
// return the value in between 0 - 2PI
float a = ((float)(encoder.getCount()%cpr)*_2PI/((float)cpr));
return a > 0 ? a : a + _2PI;
// create the generic sensor
BLDCDriver3PWM driver = BLDCDriver3PWM(16, 27, 5, 12); // (Arduino pins 5,6,10,8)
