Position control example
using SimpleFOCMini
For more information about the SimpleFOCMini check the docs.
- Channels
AandBare connected to the Arduino UNO pins2and3.
a,bandcare connected directly the motor terminal connector connectorsM1,M2andM3of the SimpleFOCMini board
SimpleFOCMini
- The most convenient way of plugging the SimpleFOCMini board to the Nucleo board is to stack it on its pins
12-8.GND-GNDIN1-13IN2-12IN3-11EN-10
Encoder code
// define Encoder
For more configuration parameters of the encoders please check the Encoder class docs.Motor code
First we need to define the BLDCMotor class with the number od pole pairs (11)
// define BLDC motor
If you are not sure what your pole pairs number is please check the find_pole_pairs.ino example.Next we need to define the BLDCDriver3PWM class with the PWM pin numbers of the motor and the driver enable pin
// define BLDC driver
BLDCDriver3PWM driver = BLDCDriver3PWM(13, 12, 11, 10);
// power supply voltage
// default 12V
// MotionControlType::torque
// MotionControlType::angle
// default P=0.5 I = 10
motor.voltage_limit = 6;
motor.LPF_velocity.Tf = 0.02;
// angle P controller
// default P=20
// default 20
motor.velocity_limit = 4;
// iterative FOC function
For more configuration parameters and control loops please check the BLDCMotor class doc.Full Arduino code
To the full code I have added a small serial commander interface, to be able to change position/angle target value in real time.
// init BLDC motor
// init driver
// init encoder
void onTarget(char* cmd){ command.motion(&motor, cmd); }
// default 12V
// default P=20
// default 20
command.add('T', doTarget, "motion control");
// function calculating the outer position loop and setting the target position
// commander interface with the user
commander.run();
