Position control example
using SimpleFOCShield
For a bit more in depth explanation of Arduino UNO and SimpleFOCShield connection please check the connection examples.
For more information about the SimpleFOCShield check the docs.
- Channels
AandBare connected to the encoder connectorP_ENC, terminalsAandB.
Small motivation :D
Encoder code
// define Encoder
For more configuration parameters of the encoders please check the Encoder class docs.Motor code
First we need to define the BLDCMotor class with the number od pole pairs (11)
// define BLDC motor
If you are not sure what your pole pairs number is please check the find_pole_pairs.ino example.Next we need to define the BLDCDriver3PWM class with the PWM pin numbers of the motor and the driver enable pin
// define BLDC driver
// power supply voltage
// default 12V
// MotionControlType::torque
// MotionControlType::angle
// default P=0.5 I = 10
// default value is 300 volts per sec ~ 0.3V per millisecond
motor.voltage_limit = 6;
// angle P controller
// default P=20
// default 20
motor.velocity_limit = 4;
// iterative FOC function
motor.move(target_angle);
For more configuration parameters and control loops please check the BLDCMotor class doc.Full Arduino code
To the full code I have added a small serial commander interface, to be able to change position/angle target value in real time.
// init BLDC motor
// init driver
// init encoder
// angle set point variable
float target_angle = 0;
void onTarget(char* cmd){ command.scalar(&target_angle, cmd); }
// default 12V
// default P=20
// default 20
command.add('T', onTarget, "target angle");
// function calculating the outer position loop and setting the target position
