SPI Magnetic sensor setup
In order to use your SPI magnetic position sensor with SimpleFOClibrary first create an instance of the MagneticSensorSPI class:
// MagneticSensorSPI(int cs, float _cpr, int _angle_register)
// cs - SPI chip select pin
// bit_resolution - magnetic sensor resolution
// angle_register - (optional) angle read register - default 0x3FFF
MagneticSensorSPI sensor = MagneticSensorSPI(10, 14, 0x3FFF);
chip_select- pin number you connected your sensor to be used with the SPI communication,bit_resolution- resolution of your sensor (number of bits of the sensor internal counter register) and yourangle register- register number containing angle value.
The defaultangle_registernumber is set to0x3FFFas it is the angle register for most of the low cost AS5048/AS5047 sensors.
Additionally the library allows you to configure SPI communication clock speed and SPI mode by setting the variables:
// spi mode (phase/polarity of read/writes) i.e one of SPI_MODE0 | SPI_MODE1 (default) | SPI_MODE2 | SPI_MODE3
sensor.spi_mode = SPI_MODE0;
// speed of the SPI clock signal - default 1MHz
sensor.clock_speed = 500000;
Finally after the configuration the only thing you need to do is to call the init() function. This function prepares the SPI interface and initializes the sensor hardware. So your magnetic sensor initialization code will look like:
sensor.spi_mode = SPI_MODE0; // spi mode - OPTIONAL
sensor.clock_speed = 500000; // spi clock frequency - OPTIONAL
MagneticSensorSPI sensor1 = MagneticSensorSPI(10, 14, 0x3FFF);
MagneticSensorSPI sensor1 = MagneticSensorSPI(9, 14, 0x3FFF);
Multiple SPI busses
For the microcontrollers where that is possible, library provides you a way to provide it the SPI bus you would like it to use instead of default SPI class.
// these are valid pins (mosi, miso, sclk) for 2nd SPI bus on storm32 board (stm32f107rc)
SPIClass SPI_2(PB15, PB14, PB13);
// init magnetic sensor
sensor.init(&SPI_2);
For the most common SPI magnetic sensors, the library provides the simplified configuration constructor. Namely for AS5047/AS5147 14-bit SPI sensors and MA70 14-bit SSI sensor.
// instance of AS5047/AS5147 sensor
MagneticSensorSPI sensor = MagneticSensorSPI(10, AS5147_SPI);
// instance of MA730 sensor
MagneticSensorSPI sensor = MagneticSensorSPI(10, MA730_SPI);
struct MagneticSensorSPIConfig_s {
int bit_resolution;
int angle_register;
int spi_mode; // default SPI_MODE0
long clock_speed; // default 1MHz
int data_start_bit; // default 13
int command_rw_bit; // default 14
int command_parity_bit; // default 15
// 12 bit, 0x3FFF angle register, spi mode 1, 1MHz, default start bit, rw command, and parity bit
MagneticSensorSPIConfig_s MySensorConfig = {
.bit_resolution=12,
.angle_register=0x3FFF,
.spi_mode=SPI_MODE1,
.clock_speed=1000000,
.data_start_bit=13,
.command_rw_bit=14,
.command_parity_bit=15
MagneticSensorSPI sensor = MagneticSensorSPI(10, MySensorConfig);
Please check the magnetic_sensor_spi_example.ino example for a quick test of your sensor. All the features of SPI magnetic sensors are implemented in the MagneticSensorSPI.cpp/h files.
class MagneticSensorSPI{
Calling
Here is a quick example for the AS5047U magnetic sensor with SPI communication:
// bit_resolution - sensor resolution
MagneticSensorSPI as5047u = MagneticSensorSPI(10, 14, 0x3FFF);
// or quick config
MagneticSensorSPI as5047u = MagneticSensorSPI(10, AS4147_SPI);
as5047u.init();
Serial.println("as5047u ready");
// update the sensor values
Serial.print(as5047u.getAngle());
Serial.println(as5047u.getVelocity());
