Fabrication guide for SimpleFOCShield
Here is a quick guide how to fabricate the Arduino SimpleFOCShield check the most recent versions . Here we will showcase the two most recent releases of SimpleFOCShield v1 and SimpleFOCShield v2.
Board releases
| SimpleFOCShield v1.3 | release v1.3 | 04/20 | Inital release |
| SimpleFOCShield v1.3.1 | release v1.3.1 | 07/20 | added Nucleo stacking support |
| SimpleFOCShield v1.3.2 | release v1.3.2 | 09/20 | added I2C pullups |
| SimpleFOCShield v1.3.3 | release v1.3.3 | 12/20 | adapted L6234 circuit + full Arduino header |
| SimpleFOCShield v2.0 | release v2.0 | 01/21 | - 3A in-line current sensing - 5V regulator - new pinout for hardware config |
| SimpleFOCShield v2.0.1 | release v2.0.1 | 01/21 | - reduced via size - configurable range |
| SimpleFOCShield v2.0.2 | release v2.0.2 | 02/21 | replaced 7805(connected to 5V) with 78M08 (connected to VIN) to be compatible with stm32 Nucleo-64 |
| SimpleFOCShield v2.0.3 | release v2.0.3 | 03/21 | - Shortened the lines from ADC to current sense - Typo fix : underside label switched phase A and phase B |
| SimpleFOCShield v2.0.4 | release v2.0.4 | 09/21 | - Pullup config simplified - Max input voltage 35V - removed CAP2 for a CL1 - Easy EDA version of the project |
Fully assembled versions
