Extending commander with custom functionality
To extend the commander interface with your own functionality that has not been implemented by the SimpleFOClibrary you only really need to:
  1. implement your callback function void myFunc(char*){}
  2. add it to the commander commander.add('.',myFunc,"..")
void myFunc(char*){
  // do something useful
Commander commander = Commander(...)
  commander.add('A',myFunc,"my functionality");
  commander.run()
Example
This is an example code of extending the commander interface with two new functionalities, turning on and off a led light and reading 5 analog pins.
// led control function
void doLed(char* cmd){
    if(atoi(cmd)) digitalWrite(LED_BUILTIN, HIGH);
    else digitalWrite(LED_BUILTIN, LOW);
// get analog input
void doAnalog(char* cmd){
    if (cmd[0] == '0') Serial.println(analogRead(A0));
    else if (cmd[0] == '1') Serial.println(analogRead(A1));
    else if (cmd[0] == '2') Serial.println(analogRead(A2));
    else if (cmd[0] == '3') Serial.println(analogRead(A3));
    else if (cmd[0] == '4') Serial.println(analogRead(A4));
    // define pins
    pinMode(LED_BUILTIN, OUTPUT);
    pinMode(A0, INPUT);
    pinMode(A1, INPUT);
    pinMode(A2, INPUT);
    pinMode(A3, INPUT);
    pinMode(A4, INPUT);
    // Serial port to be used
    // add new commands
    command.add('L', doLed, "led on/off");
    command.add('A', doAnalog, "analog read A0-A4");
    Serial.println(F("Commander listening"));
    Serial.println(F(" - Send ? to see the node list..."));
    Serial.println(F(" - Send L0 to turn the led off and L1 to turn it off"));
    Serial.println(F(" - Send A0-A4 to read the analog pins"));
    _delay(10);
Then in your serial terminal you can just
$ ?            # list the commands
L: led on/off
A: analog read A0-A4
$ L0           # led off
$ A1           # read A1
321
$ A3           # read A3
1023
$ L1           # led on
$ L0           # led off
