Open loop Motion control
Position control Velocity control
SimpleFOClibrary gives you the choice of using 2 different open-loop control strategies, control strategies that do not require a position sensor
Index search uses also uses open-loop position control, but has some additional parameters, see index search
// MotionControlType::velocity_openloop - velocity open-loop control
// MotionControlType::angle_openloop - position open-loop control
