I2C Magnetic sensor setup
Now in order to use your I2C magnetic position sensor with SimpleFOClibrary first create an instance of the MagneticSensorI2C class:
// MagneticSensorI2C(uint8_t _chip_address, float _cpr, uint8_t _angle_register_msb)
// chip_address - I2C chip address
// bit_resolution - resolution of the sensor
// angle_register_msb - angle read register msb
// bits_used_msb - number of used bits in msb register
MagneticSensorI2C sensor = MagneticSensorI2C(0x36, 12, 0x0E, 4);
The parameters of the class are:
chip_address- I2C address of the magnetic sensorbit_resolution- resolution of your sensor (number of bits of the sensor internal counter register) and yourangle_register_msb- register number containing the MSB part of the angle value. ( ex. AS5600 -0x0E, AS5048 -0xFE)bits_used_msb- number of used bits in MSB register
How to find the MSB register values and used bits value?
Since I2C registers are Byte(8-bit) registers they contain the 12-14 bit angle representation separated in two Byte addresses, MSB(most significant byte) and LSB(least significant byte). To instantiate the I2C magnetic sensor you need to provide the MSB register address and tell the library how is the angle value separated in the two registers. By specifying the number of bits used in the MSB register and specifying thebit_resolutionvalue the library can calculate how many bits are used in the LSB register and can reconstruct the complete angle value.
Example MSB/LSB division:
- AS5600 (12 bit) - MSB (4bit), LSB (8bit)
- AS5048B (14bit): - MSB (8bit), LSB(6bit)
AS5600 example
- First we open AS5600 sensor's datasheet .
- In the datasheet we find the table of I2C registers (page 18)
- The
angle_register_msbvalue is the first (upper in datasheet) register value -0x0E- The
bits_used_msbvalue is number of bits in the MSB register -4
Finally, after the configuration, you just call the init() function. This function prepares the I2C interface and configures the sensor hardware. So your magnetic sensor initialization code will look like:
If you wish to use more than one magnetic sensor using SPI interface, make sure your sensors have different addresses, here is a simple example:
MagneticSensorI2C sensor1 = MagneticSensorI2C(0x36, 12, 0x0E, 4);
MagneticSensorI2C sensor2 = MagneticSensorI2C(0x37, 12, 0x0E, 4);
Multiple I2C busses
Additionally, the library enables you to already configured I2C bus to the sensor using the init() function.
Wire.setClock(400000);
Wire.begin();
// providing
sensor.init(&Wire)
For microcontrollers where that is possible (not for Arduino UNO) you can use different I2C busses for multiple I2C sensors. See the examples in utils > sensor_test > magnetic_sensors > magnetic_sensor_i2c_dual_bus_examples.
For the most common I2C magnetic sensors, the library provides the simplified configuration constructor. Namely for AS5600 12-bit sensor and AS5048 14-bit sensor.
// instance of AS5600 sensor
MagneticSensorI2C sensor2 = MagneticSensorI2C(AS5600_I2C);
// instance of AS5048B sensor
MagneticSensorI2C sensor2 = MagneticSensorI2C(AS5048_I2C);
struct MagneticSensorI2CConfig_s {
int chip_address;
int bit_resolution;
int angle_register;
int data_start_bit;
// configuration for AS5600 sensor
MagneticSensorI2CConfig_s MySensorConfig = {
.chip_address = 0x36,
.bit_resolution = 12,
.angle_register=0x0E,
.data_start_bit=11
MagneticSensorI2C sensor = MagneticSensorI2C(MySensorConfig);
Please check the magnetic_sensor_i2_example.ino example for a quick test of your sensor. All the features of I2C magnetic sensors are implemented in the MagneticSensorI2C.cpp/h files.
class MagneticSensorI2C{
Here is a quick example for AS5600 magnetic sensor with I2C communication:
MagneticSensorI2C as5600 = MagneticSensorI2C(0x36, 12, 0x0E, 4);
// or quick config
MagneticSensorI2C as5600 = MagneticSensorI2C(AS5600_I2C);
as5600.init();
Serial.println("AS5600 ready");
// update the sensor values
Serial.print(as5600.getAngle());
Serial.println(as5600.getVelocity());
