In-line current sensing
Inline current sensing technique is the simplest one to use and the most precise one. The shunt resistors are placed in-line with motor phases and the current measured on these shunt resistors will be motor phase current regardless of the state of the PWM duty cycle. This implementation is therefore very suitable for Arduino devices due to the fact that adc can be sampled at any time to read the current and the adc acquisition duration is as important as for the other current sensing approaches. The downside of this approach is the hardware, this current sensing architecture requirers high-precision bidirectional amplifiers with much better PWM rejection than the regular low-side or high-side amplifiers.
In-line current sensing is currently supported for almost all MCU architectures supported by the SimpleFOClibrary. Only not supported architecture is teh ESP8266 which does not have 2 ADC pins, making it unable to run FOC.
MCUIn-line Current sensing
Arduino (8-bit)✔️
Arduino DUE✔️
stm32✔️
stm32 B_G431B_ESC1✔️
esp32✔️
esp8266❌
samd21✔️
samd51✔️
teensy✔️
Raspberry Pi Pico✔️
Portenta H7✔️
Hardware configuration
// InlineCurrentSensor constructor
//  - shunt_resistor  - shunt resistor value
//  - gain  - current-sense op-amp gain
//  - phA   - A phase adc pin
//  - phB   - B phase adc pin
//  - phC   - C phase adc pin (optional)
InlineCurrentSense current_sense  = InlineCurrentSense(0.01, 20, A0, A1, A2);
To instantiate the inline current sensor using the SimpleFOClibrary just create an instance of the class InlineCurrentSense. This class takes as a parameter shunt resistance value shunt_resistor, amplification gain gain and two or three ADC channel pins depending on the available measuring hardware that you might have. It is important to specify right adc channels for right driver/motor phase. So if your pin A0 measures the phase current A and pin A1 measures the phase current B make sure to put provide them to the constructor in that order.
Measuring 2 out of 3 currents
Field Oriented Control algorithm can run with both 2 or 3 phase current measurements. If measuring 2 out of 3 currents, when defining your InlineCurrentSense class put the flag _NC (not connected) to the phase value you are not using.
For example if measuring the current on phases A (analog pin A0) and C (analog pin A1) and not measuring the current on the phase B, then you’ll define your current sense class as:
InlineCurrentSense current_sense  = InlineCurrentSense(shunt_resistor, gain, A0, _NC, A1);
Some more examples:
InlineCurrentSense current_sense  = InlineCurrentSense(shunt_resistor, gain, _NC, A0, A1); // when measuring B and C phase currents and not measuring A
InlineCurrentSense current_sense  = InlineCurrentSense(shunt_resistor, gain, A0, A1, _NC); // when measuring A and B phase currents and not measuring C
// or
InlineCurrentSense current_sense  = InlineCurrentSense(shunt_resistor, gain, A0, A1); // when measuring A and B phase currents and not measuring C
Custom gains
The constructor of the InlineCurrentSense class only allows you to specify one shunt resistor value and one amplification gain. If your hardware configuration has different shunt/amp values for different phases you can specify them by changing the gain_x attribute:
For example, Arduino SimpleFOCShield v2 has the phase B of the current sensing inverted. So in its case you can specify:
// inverse current sensing gain on phase b
current_sense.gain_b *= -1;
Initialising the current sense
Once the current sense has been created it can be initialised. This init() function configures the ADC hardware for reading and finds the zero offsets of the ADC for each channel.
// init current sense
Init function is responsible for
  • configuring ADC for current sensing
  • calibration - offset removal
If for some reason the ADC configuration fails this function will return 0 if everything went well the function will return 1. So we suggest you to check if the init function was executed successfully before continuing:
if (current_sense.init())  Serial.println("Current sense init success!");
else{
  Serial.println("Current sense init failed!");
  return;
Once when your current sense has been intialised and calibrated you can start measuring the currents!
To use the InlineCurrentSense with the FOC algorithm, first thing you’ll need to do is to associate (link) your current sense with the BLDCDriver:
// link current sense and driver
Current sense will be using driver parameters for different synchronisation and calibration procedures.
API change - SimpleFOClibrary v2.2.2
Driver linking to the current sense is introduced from the library version v2.2.2 in order to propagate different hardware specific parameters in between ADC and PWM timers needed for advanced synchronisation for current sensing.
Once the driver is linked to the current sense, last step is to link the current sense with the BLDCMotor you wish to use it with:
Where to place the current_sense configuration in your FOC code?
It is very important that the the current sensing init function is called after the BLDCMotor and BLDCDriver init functions are called. Which will make sure that the driver is enabled when current sense calibration is taking place. Also, it is important that the current sense init function is called before starting the foc algorithm with the initFOC function.
So the suggested code structure would be:
  // driver init
  // motor init
  // start the FOC
Function initFOC() will make sure that the BLDCDriver and CurrentSense classes are both well aligned, it is very important that the phase A of the currnet sense is exactly the phase A of the driver, phase B of the current sense exactly pahse B of the driver and the same for the phase C. To verify this, the initFOC will be calling the current sense’s funciton current_sense.driverAlign(...).
Alignment with the driver phases driverAlign(...)
The current sense and the driver alignment inside initFOC is done by calling the function:
current_sense.driverAlign(voltage_sensor_align);
This function will be using the driver instance (linked to the current sense with current_sense.linkDriver(&driver)) to apply the voltage (voltage can be set using the parameter motor.voltage_sensor_align) to each of the phases and checks if the measured currents correspond to the directions of the applied voltages. This alignment procedure is able to correct for:
  • Incorrect order of adc pins
  • Incorrect gain sign
  • 0 - fail
  • 1 - success and nothing changed
  • 2 - success but pins reconfigured
  • 3 - success but gains inverted
  • 4 - success but pins reconfigured and gains inverted
// skip alignment procedure
For example, Arduino SimpleFOCShield v2, you would have a code similar to this:
// one possible combination of current sensing pins for SimpleFOCShield v2
// shunt - 10milliOhm
// gain  - 50 V/V
InlineCurrentSense current_sense  = InlineCurrentSense(0.01, 50.0, A0, A2);
voi loop(){
  // driver init
  // motor init
  // invert phase b gain
  current_sense.gain_b *=-1;
  // skip alignment
  // start the FOC
Standalone current sense
To use your inline current sensor as a stand-alone sensor after you have configured the hardware and calibrated it you can read the phase currents by calling:
PhaseCurrent_s  current = current_sense.getPhaseCurrents();
Serial.println(current.a);
Serial.println(current.b);
If you are using only two phase current measurements in your InlineCurrentSense, it will return the third current current.c equal to 0.
Serial.println(current.d);
Serial.println(current.q);
Example code
Here is a simple example of a inline current sense as a stand-alone sensor using the SimpleFOClibrary and SimpleFOCShield v2.
// current sensor
// shunt resistor value
// gain value
// pins phase A,B
  // for SimpleFOCShield v2.01/v2.0.2
  Serial.println("Current sense ready.");
    Serial.print(currents.c*1000); // milli Amps
    Serial.println(current_magnitude*1000); // milli Amps
