Low-side current sensing
Low-side current sensing is probably the most common current sensing technique. The main reason why is because it does not require neither high-performance PWM rejection current sense amplifiers (as inline does) neither high-voltage supporting amplifiers (as high-side does). The shunt resistors are always placed in between low side mosfets and the ground making sure that the amplifiers always have very low voltages on their terminals. The main drawback of this approach is that, since the current passing through the shunt resistors is phase current only if the corresponding low side mosfet is ON, we can only measure it in those moments. The PWM frequency is usually 20 to 50 kHz, which means that the low-side mosfets turn on and off 20,000 to 50,000 times per second, therefore the synchronization in between PWM setting and ADC acquisition is very very important.
Low side current sensing for all the architectures is on our road-map and we are actively working on it. The main issue at the moment is very hardware specific synchronisation procedure of the PWM generation and ADC triggering. Therefore we are attacking one MCU architecture at the time. 😃
Low side current sensing is currently supported for several MCU architectures supported by the SimpleFOClibrary. ESP32 architecture has the most generic support, supporting multiple motors per chip. Stm32 families f1, f4 and g4 are initially supported and support low-side sensing for only one motor. A special case of the stm32 board is the BG431_ESC1 development kit which has very specific low-side implementation for its hardware configuration, and it is fully supported by the library. Samd21 architecture is under development, it has an initial support for only one motor, but for now as it has not been extensively tested, we suggest not to rely on our implementation.
| MCU | Low-side Current sensing |
| Arduino (8-bit) | ❌ |
| Arduino DUE | ❌ |
| stm32 (in general) | ❌ |
| stm32f1 family | ✔️ (one motor) |
| stm32f4 family | ✔️ (one motor) |
| stm32g4 family | ✔️ (one motor) |
| stm32 B_G431B_ESC1 | ✔️ |
| esp32 | ✔️ |
| esp8266 | ❌ |
| samd21 | ✔️/❌ (one motor, poorly tested) |
| samd51 | ❌ |
| teensy | ❌ |
| Raspberry Pi Pico | ❌ |
| Portenta H7 | ❌ |
Important hardware considerations
Low-side current sensing requires very high synchronisation of the PWM generated by the driver and the ADC triggering. There are two main considerations to have in mind when choosing your driver parameters:
- PWM frequency considerations
- PWM pins
See more info about driver paramers in the driver docs!
1. PWM frequency considerations
As the ADC conversion takes some time to finish and as this conversion has to happen only during the specific time window ( when all the phases are grounded - low-side mosfets are ON ) it is important to use an appropriate PWM frequency. PWM frequency will determine how long each period of the PWM is and in term how much time the low-side switches are ON. Higher PWM frequency will leave less time for the ADC to read the current values.
On the other hand, having higher PWM frequency will produce smoother operation, so there is definitely a tradeoff here.
RULE OF THUMB: PWM frequency
The rule of thumb is to stay arround 20kHz.driver.pwm_frequency = 20000;
2. PWM pin considerations
As ADC conversion has to be synchronised with the PWM generated on ALL the phases, it is important that all the PWM generated for all the phases have aligned PWM. Since the microcontrollers usually have more than one timer for PWM generation on its pins, different architectures of microcontrollers have different degrees of alinement in between the PWM generated from different timers.
RULE OF THUMB: PWM timer pins
In order to maximise your chances for the low-side current sensing to work well we suggest to make sure that the PWM pins chosen for your driver all belong to the same Timer. Finding out which pins belong to different timers might require some time to be spent in the MCU datasheet 😄 You can also always ask the community for help - community link!
Hardware configuration
// LowsideCurrentSense constructor
// - shunt_resistor - shunt resistor value
// - gain - current-sense op-amp gain
// - phA - A phase adc pin
// - phB - B phase adc pin
// - phC - C phase adc pin (optional)
LowsideCurrentSense current_sense = LowsideCurrentSense(0.01, 20, A0, A1, A2);
To instantiate the low-side current sensor using the SimpleFOClibrary just create an instance of the class LowsideCurrentSense. This class takes as a parameter shunt resistance value shunt_resistor, amplification gain gain and two or three ADC channel pins depending on the available measuring hardware that you might have. It is important to specify right adc channels for right driver/motor phase. So if your pin A0 measures the phase current A and pin A1 measures the phase current B make sure to put provide them to the constructor in that order.
Measuring 2 out of 3 currents
Field Oriented Control algorithm can run with both 2 or 3 phase current measurements. If measuring 2 out of 3 currents, when defining your LowsideCurrentSense class put the flag _NC (not connected) to the phase value you are not using.
For example if measuring the current on phases A (analog pin A0) and C (analog pin A1) and not measuring the current on the phase B, then you’ll define your current sense class as:
LowsideCurrentSense current_sense = LowsideCurrentSense(shunt_resistor, gain, A0, _NC, A1);
Some more examples:
LowsideCurrentSense current_sense = LowsideCurrentSense(shunt_resistor, gain, _NC, A0, A1); // when measuring B and C phase currents and not measuring A
LowsideCurrentSense current_sense = LowsideCurrentSense(shunt_resistor, gain, A0, A1, _NC); // when measuring A and B phase currents and not measuring C
// or
LowsideCurrentSense current_sense = LowsideCurrentSense(shunt_resistor, gain, A0, A1); // when measuring A and B phase currents and not measuring C
Custom gains
The constructor of the LowsideCurrentSense class only allows you to specify one shunt resistor value and one amplification gain. If your hardware configuration has different shunt/amp values for different phases you can specify them by changing the gain_x attribute:
For example AliExpress DRV8302 board has all the current sensing phases inverted inverted. So in its case you can specify:
// inverse current sensing gain
current_sense.gain_a *= -1;
current_sense.gain_b *= -1;
current_sense.gain_c *= -1;
Synchronising the current sense with the driver PWM
Since the low-side current sensing technique requires triggering of the ADC acquisition exactly when all the low-side mosfets are ON (when all the phases are grounded), to use the LowsideCurrentSense with the FOC algorithm, first thing you’ll need to do is to associate (link) your current sense with the BLDCDriver:
// link current sense and driver
Current sense will be using driver parameters for different synchronisation and calibration procedures.
API change - SimpleFOClibrary v2.2.2
Driver linking to the current sense is introduced from the library version v2.2.2 in order to propagate different hardware specific parameters in between ADC and PWM timers needed for advanced synchronisation for current sensing.
Initialising the current sense
Once the current sense has been created and linked with the driver it can be initialised. This init() function configures the ADC hardware for reading and finds the zero offsets of the ADC for each channel.
// init current sense
Init function is responsible for
- configuring ADC for current sensing
- calibration - offset removal
If for some reason the ADC configuration fails this function will return 0 if everything went well the function will return 1. So we suggest you to check if the init function was executed successfully before continuing:
if (current_sense.init()) Serial.println("Current sense init success!");
else{
Serial.println("Current sense init failed!");
return;
Once when your current sense has been intialised and calibrated you can start measuring the currents!
To use the LowsideCurrentSense with the FOC algorithm all you need to do is to add it to link it with the BLDCMotor you wish to use it with:
Where to place the current_sense configuration in your FOC code?
It is very important that the the current sensing init function is called after the BLDCMotor and BLDCDriver init functions are called. Which will make sure that the driver is enabled when current sense calibration is taking place. Also, it is important that the current sense init function is called before starting the foc algorithm with the initFOC function.
So the suggested code structure would be:
// driver init
// motor init
// start the FOC
Function initFOC() will make sure that the BLDCDriver and LowsideCurrentSense classes are both well aligned, it is very important that the phase A of the current sense is exactly the phase A of the driver, phase B of the current sense exactly pahse B of the driver and the same for the phase C. To verify this, the initFOC will be calling the current sense’s function current_sense.driverAlign(...).
Alignment with the motor phases driverAlign(...)
The current sense and the driver alignment inside initFOC is done by calling the function:
current_sense.driverAlign(voltage_sensor_align);
This function will be using the driver instance (linked to the current sense with current_sense.linkDriver(&driver)) to apply the voltage (voltage can be set using the parameter motor.voltage_sensor_align) to each of the phases and checks if the measured currents correspond to the directions of the applied voltages. This alignment procedure is able to correct for:
- Incorrect order of adc pins
- Incorrect gain sign
0- fail1- success and nothing changed2- success but pins reconfigured3- success but gains inverted4- success but pins reconfigured and gains inverted
// skip alignment procedure
For example AliExpress DRV8302 board , you would have a code similar to this: For example, Arduino SimpleFOCShield v2, you would have a code similar to this:
// one possible combination of current sensing pins for SimpleFOCShield v2
// shunt - 5milliOhm
// gain - 12.22 V/V
LowsideCurrentSense current_sense = LowsideCurrentSense(0.005f, 12.22f, IOUTA, IOUTB, IOUTC);
voi loop(){
// driver init
// motor init
// invert phase b gain
current_sense.gain_a *=-1;
current_sense.gain_b *=-1;
current_sense.gain_c *=-1;
// skip alignment
// start the FOC
See the full example for the Aliexpress DRB8302 based board in the library examples /examples/hardware_specific_examples/DRV8302_driver/esp32_current_control_low_side.
Standalone current sense
Since the low-side current sense has to be synchornised with PWM of a driver of interest it does not make sense to use it as a stand-alone sensor. But once when you linked the current sense with the BLDCMotor you can use it to read your phase currents, overall current magnitude and DQ currents.
Reading the phase currents can be done by calling:
PhaseCurrent_s current = current_sense.getPhaseCurrents();
Serial.println(current.a);
Serial.println(current.b);
If you are using only two phase current measurements in your LowsideCurrentSense, it will return the third current current.c equal to 0.
Serial.println(current.d);
Serial.println(current.q);
Example code
Here is a simple example of a low-side current sense using the SimpleFOClibrary and to read the motor currents directly.
// define the motor and the driver
motor = ...
driver = ...
// current sensor
// shunt resistor value
// gain value
// pins phase A,B
LowsideCurrentSense current_sense = LowsideCurrentSense(0.01, 50.0, A0, A2);
// init driver
// init motor
Serial.println("Setup ready.");
// foc and motion controls
Serial.print(currents.c*1000); // milli Amps
Serial.println(current_magnitude*1000); // milli Amps
