Full motor configuration using the Commander
When using a standard callback for BLDCMotor and StepperMotor classes:commander.motor(&motor,cmd) the user will have available set of possible commands:
- Q - Q current PID controller & LPF (see pid and lpf for commands)
- P - proportional gain
- I - integration gain
- D - derivative gain
- L - saturation limit
- R - ramp parameter
- F - low pass filtering time constant
- D - D current PID controller & LPF (see pid and lpf for commands)
- V - Velocity PID controller & LPF (see pid and lpf for commands)
- A - Angle PID controller & LPF- (see pid and lpf for commands)
- L - Limits
- C - Current
- U - Voltage
- V - Velocity
- R - Motor phase resistance
- K - Motor KV rating
- S - Sensor offsets
- M - sensor offset
- E - sensor electrical zero
- W - PWM settings
- T - pwm modulation type
- C - pwm waveform centering boolean
- M - Monitoring control
- D - downsample monitoring
- C - clear monitor
- S - set monitoring variables
- G - get variable value
- C - Motion control type config - see motion control
- D - downsample motion loop
0- torque1- velocity2- angle3- velocity_openloop4- angle_openloop
- T - Torque control type - see motion control
0- voltage1- dc_current2- foc_current
- E - Motor status (enable/disable) - see motion control
0- enable1- disable
- else - Target setting interface - see motion control target
Depends of the motion control mode:- torque mode - torque target (ex.
M2.5) - velocity (open and closed loop) mode - velocity target and torque limit (ex.
M10 2.5orM10to only change the target without limits) - angle (open and closed loop) mode - angle target, velocity limit, torque limit (ex.
M3.5 10 2.5orM3.5to only change the target without limits)
All built-in commands and subcommands are defined in the library source, in file src/communication/commands.h
For example if you have a BLDC motor added to the commander:
BLDCMotor motor = ....
Commander commander = ...
void onMotor(char* cmd){ commander.motor(&motor,cmd); }
commander.add('M',onMotor,"my motor motion");
commander.run();
You will be able to configure (set and get) its parameters from serial monitor:
$ MVP # get PID velocity P gain
PID vel| P: 0.20
$ MVP1.2 # set PID velocity P gain
PID vel| P: 1.20
$ MAI # get PID angle I gain
PID angle| I: 0.00
$ MAF # get LPF angle time constant
LPF angle| Tf: 0.00
$ MLV50.4 # set velocity limit
Limits| vel: 50.4
$ MLC # get current limit
Limits| curr: 0.5
$ MT # get torque control mode
Torque: volt
$ MT1 # set torque control mode
Torque: dc curr
$ MT2 # set torque control mode
Torque: foc curr
$ ME # get motor status enabled/disabled
Status: 1
$ MSM # get sensor offset
Sensor| offset: 0.0
$ MSM1.2 # set sensor offset
Sensor| offset: 1.2
$ MC # get motion control mode
Motion: torque
$ MC3 # set motion control mode
Motion: vel open
$ MC2 # set motion control mode
Motion: angle
$ MCD100 # get motion control downsampling
Motion: downsample: 100
$ MMG0 # get variable - target
Monitor | target: 0.0
$ MMG1 # get variable - voltage q
Monitor | Vq: 1.4
$ MMG6 # get variable - angle
Monitor | angle: 23.5
Monitor | angle: 24.6
Monitor | angle: 25.5
$ M0 # set target
Target: 0.0
$ M0.4 # set target
Target: 0.4
$ @1 # set verbose mode: on_request
Verb | on!
26.5
$ MMG5 # get variable - velocity
2.57
$ #6 # set 6 decimal places
Decimal: 6
27.732821
$ @0 # set verbose mode: nothing
Verb: off!
$ @2 # set verbose mode: user_friendly
Verb: on!
Monitor | angle: 25.532131
Motor monitoring control commands
Commander interface enables the user to control the output of the monitoring functionality. The combination of the two enables user a full control of the motor configuration and tuning as well as full control of variables that are outputted to the user. In order to use his functionality the user needs to enable monitoring for the motor which is really straight-forward:
commander.add('M',onMotor,"my motor");
motor.monitor();
commander.run();
Finally once the motor is added to the commander interface the use will be able to configure the monitoring with commands:
- C - clear monitor
Using these commands you can change the downsampling rate (motor.monitor_downsampling) of the monitor() function that will determine your output sampling frequency. For example if your loop time is around 1ms, then with downsampling of monitor function with the rate of 100, it will output the motor variables each 100ms.
If monitor dowsampling is set to 0 the monitor() function is disabled. The same is true if the motor.monitor_variables bitmap is empty (equal to 0). Therefore the command C effectively does:
// when command MC is called
motor.monitor_variables = 0;
Finally the command MS is used to get/set the motor.monitor_variables bitmap.
Therefore te communication could look something like this:
$ MMD # get monitor downsampling rate
Monitor | downsample: 10
$ MMD1000 # set monitor downsampling rate
Monitor | downsample: 1000
$ MMS # get monitor variables
Monitor | 0000000
$ MMS1000001 # set monitor variables (target and angle)
Monitor | 1000001
1.000 0.999
1.000 0.985
1.000 1.064
1.000 1.040
$ MMS0100000 # set monitor variables (voltage q)
Monitor | 0100000
1.234
-0.345
0.772
$ MMC # clear monitoring variables
Monitor | clear
$ MMS # get monitoring variables
Monitor | 0000000
📈 Good practice for visualization
When using monitoring to tune the motion control parameters or just to visualize the different variables it makes sense to disable the commander outputs so that in the serial monitor you only have monitor output. To do that use the modeVerboseMode::nothingof the commander by sending the command@0. See all commander commands.
Example code using the motor commands
This is one simple example of using motor commands with monitoring in the code. For more examples browse through the library examples, especially through the examples/utils/communication_tes/commander folder.
motor.monitor_downsample = 0; // initially disable real-time monitoring
motor.target = 2;
// define the motor id
command.add('A', onMotor, "motor");
// monitoring
motor.monitor();
SimpleFOCStudio by @JorgeMaker
SimpleFOCStudio is an awesome application built by @JorgeMaker which we will try to keep up to date with out library. It is a python application that uses commander interface for tunning and configuring the motor.
For more info how to install and use this application visit the studio docs .
