Let’s get started
Once when you have your SimpleFOClibrary installed and you have all the necessary hardware, we can finally start the fun part, let’s white the code and move the motor!
Step 1. Testing the sensor
The first sign that tells us that everything is well connected is if the sensor readings are good. To test the sensor please browse the library examples examples/utils/sensor_test and find the example for your sensor. The example will have a structure something like this:
// interrupt routine intialisation
Serial.println("Encoder ready");
Make sure to change the sensor parameters to suite your application, such as pin numbers, impulses per revolution, bus addresses and similar. Make sure to go through the sensor docs if you are not sure in some of the parameters.
If your sensor is well connected and if everything works well, you should have in your serial terminal an output of your sensor angle and velocity.
☑️ Simple test
Make sure to test that one rotation of the motor gives you 6.28 radians of sensor angle.
Step 2. Testing the driver
Once your sensor is working you can proceed to the driver test. The simplest way to test the driver is to use the library examples. If you have a luxury of time you can test the driver using the examples in examples/utils/driver_standalone_test folder. These examples test the driver as a standalone module and with them you can set any voltage value to any of the driver phases.
// BLDC driver instance
driver.pwm_frequency = 50000;
driver.voltage_limit = 12;
// driver init
// enable driver
driver.enable();
// setting pwm (A: 3V, B: 1V, C: 5V)
driver.setPwm(3,1,5);
☑️ Simple tests
Make sure that all phases output PWM signals, you can try to connect a small led light in between each phase and ground or just measure it with the multimeter.
Step 2. Testing the driver + motor combination - open-loop
If you already have your motor connected and if you are sure your driver works well we advise you to test the motor+driver combination using the open-loop motion control examples in the examples/motion_control/open_loop_motion_control. If your driver is not the same as the ones provided in the examples go though the driver docs and find the driver and the code that will work for you. Additionally you can browse through the examples in teh examples/utils/driver_standalone_test folder and see the used in there.
Now here is an example of the open-loop velocity control for the BLDCDriver3PWM:
// BLDCMotor motor = BLDCMotor(pole pair number, phase resistance (optional) );
// BLDCDriver3PWM driver = BLDCDriver3PWM(pwmA, pwmB, pwmC, Enable(optional));
// limiting motor movements
// motor.phase_resistance = 3.52 // [Ohm]
// motor.current_limit = 2; // [Amps] - if phase resistance defined
motor.voltage_limit = 3; // [V] - if phase resistance not defined
motor.velocity_limit = 5; // [rad/s] cca 50rpm
// open loop control config
// init motor hardware
// using motor.voltage_limit and motor.velocity_limit
This example code has few very important rules.
- Make sure you use the right driver class and right pwm pins, this one is usually very simple and you can find a lot of docs about these things in our driver docs. If you are not sure and cannot seem to make it work please do not hesitate to ask in our community forum.
- Make sure to use proper voltage limit.
motor.voltage_limitwill directly determine the current passing through the motor:current = phase_resistance*motor.voltage_limit. So to avoid too high currents please try to find what is the phase resistance of your motor and set themotor.voltage_limitsuch that the current does not surpass 2 Amps for example:motor.voltage_limit = 2*phase_resistance. The best option would be to provide your phase resistance value to the motor by setting the parametermotor.phase_resistanceand then you can usemotor.current_limitinstead of themotor.voltage_limitmaking this issue much simpler. If you cannot find the phase resistance of your motor and cannot measure it with your multimeter start small:motor.voltage_limit < 1; - Make sure to put the right pole pair number. This you can find in most data-sheets, if you are not sure what is the true number don’t worry this step in intended to test exactly this value. 😄
☑️ Simple tests
1. In velocity mode, set your target velocity of your motor to 6.28 rad/s, this should be exactly one rotation per second.
2. In position mode, set the target position of 6.28 rad, it should be exactly one rotation
If it is not that means your pole pairs number is probably not good,, try changing it until you get exactly one rotation (or one rotation per second in velocity mode)
Step 3. Closed-loop control - torque using voltage
Once you have a working sensor, working motor and driver you can proceed to the closed-loop motion control testing. The first one to test is the torque control mode using voltage, this one is the simplest form of the closed loop control that is available in the SimpleFOClibrary. You can find the examples of this torque mode for different sensors in the library examples folder examples/motion_control/torque_control. Here is an example of the BLDCMotor3PWM driver and Encoder as position sensor:
// aligning voltage
motor.voltage_sensor_align = 5;
// add current limit
// set the initial motor target
// motor.target = 0.2; // Amps - if phase resistance defined
motor.target = 2; // Volts
// command.add('T', doTarget, "target current"); // - if phase resistance defined
command.add('T', doTarget, "target voltage");
Serial.println(F("Set the target using serial terminal:"));
Until now, you already know the good configuration of your sensor, your driver and your motor. If everything worked until this point you most probably will not have any issues with this step as well.
There are only two important steps to be taken here, make sure you use not too high motor.voltage_sensor_align value to prevent too high currents. The rule is the same as for the motor.voltage_limit for the open loop. If you are not sure what is your phase resistance, start small: motor.voltage_sensor_align < 1. Additionally, you can define the motor phase resistance as well and then use the motor.current_limit variable, this variable will limit the motor.voltage_sensor_align and you will not have to worry about it any more. But if you specify the phase resistance value you will no longer be setting voltage command to the motor but current command, see torque control docs for more info.
Second important tip is to use monitoring functionality. This will help you to debug the possible issues that might arise and it will output the motor status during the initialization and the alignment. If the initialisation fails the motor will be disabled you will be able to move the motor by hand without any resistance, if the code works your motor will start spinning and you will be abele to set the voltage (current if motor.phase_resistance set) through the serial terminal.
☑️ Simple test
Make sure that the motor intialisation has finished well. Monitoring will tell you the sensnor offset, direciton, pole pairs check and it will tell you if it has been successful or if it failed.
Step 5. Testing the current sense - if available
If your setup has current sensing that is supported by the SimpleFOClibrary then we would suggest you to still make sure that you can run at least closed-loop torque control using voltage (Step 3.) before doing this step.
The best way to start is to add the current sensing to the code of the torque control using voltage (step 3.) and output the d and q currents to the serial terminal using monitoring.
Here is the an example of a such code:
// current sensor
// aligning voltage
motor.monitor_downsampling = 100; // set downsampling can be even more > 100
motor.monitor_variables = _MON_CURR_Q | _MON_CURR_D; // set monitoring of d and q currents
command.verbose = VerboseMode::nothing; // disable commander output to serial
// display the currents
motor.monitor();
This example code is almost exactly the same as the step 3. code so you should not have much troubles configuring motor, sensor and driver. In this step you will be testing if your current sense is working well. In the call of the motor.monitor() function the current sense will be read and the current d and q are going to be outputted to the serial terminal. You can open the Serial Plotter to visualise them.
☑️ Simple tests
1. Hold the motor with your hand and chaneg different target voltage/current values. Make sure that the current d is very close to 0 when the motor is static. And make sure that the current q is proportional to the voltage you are setting to the motor.
2. Leave the motor to rotate. See that your currents d and q drop to a lower level then for static motor. Also try to see that the current d is almost 0 for low velocities and starts rising proportionally to the motor velocity.
Please go through the current sense docs to see the supported sensors and all the configuration parameters.
Step 6. Full FOC motion control using current sensing - if available
Once you have your motor, position sensor, driver and current sense configured and tested you can got proceed to the true foc control.
BLDCDriver3PWM driver = BLDCDriver3PWM(5, 10, 6, 8);
// inline current sensor instance
motor.PID_velocity.P = 0.05;
motor.PID_velocity.I = 1;
motor.PID_velocity.D = 0;
motor.voltage_limit = 12;
// angle loop controller
// angle loop velocity limit
motor.velocity_limit = 20;
motor.monitor_downsampling = 0; // initially disable the real-time monitor
// current sense init and linking
motor.target = 2;
Serial.println(F("Motor commands sketch | Initial motion control > torque/current : target 0Amps."));
// iterative function setting the outer loop target
// motor monitoring
motor.monitor();
To see all of the FOC torque control parameters please visit the torque control docs. The goon news is that if you have set the phase resistance during the tuning the velocity and position motion control loops in step 4. you will most probably not need to retune them.
However the most important tip is still to use the commander interface to tune hte torque control PID controller and Low pas filter parameters, this way you will be able to test quickly and change the parameters of controllers in real-time and see what will happen. One time you are satisfied you can write these values in code and quit using the commander.
☑️ Simple test
Set your target current to 0Amps and try to move the motor by hand, make sure it feels like there is absolutely no resistance, like the motor is disabled. Then try to set a small current (<0.5A) value and see if you can feel the motor force acting on your hand. If you can feel it you should be ready to go!
