PWM output Magnetic sensor setup
In order to use your PWM output magnetic position sensor with SimpleFOClibrary first create an instance of the MagneticSensorPWM class:
// MagneticSensorPWM(uint8_t _pinPWM, int _min_raw_count, int _max_raw_count)
// - _pinPWM: the pin that is reading the pwm from magnetic sensor
// - _min_raw_count: the minimal length of the pulse (in microseconds)
// - _max_raw_count: the maximal length of the pulse (in microseconds)
MagneticSensorPWM sensor = MagneticSensorPWM(2, 4, 904);
pinPWM- the pin that is reading the analog output from magnetic sensor ,min_raw_count- the smallest expected pulse time in microseconds. This is typically the length of init time of the pulsemax_raw_count- the largest pulse time in microseconds. This is the value of init pulse time plus the data sending time.
๐ก Find out min and max
Every mcu is a bit different and every sensor as well so we advise you to use the provided example in theexamples/sensor_test/magentic_sensor_pwm_example/find_raw_min_maxto find out the maximal and minimal values of your sensor.
๐ See page 27 of the AS5048 datasheet or AS5600 datasheet for more in depth explanation about how the PWM sensors encode the angle. AS5048 , AS5600
There are two ways to use the PWM sensors implemented in this library:
- Blocking way - based on
pulselnfunction - Interrupt based, non-blocking
Blocking implementation
After the creation of the sensor class the only thing you need to do is to call the init() function. This function initializes the sensor hardware. So your final magnetic sensor code will look like:
MagneticSensorPWM sensor1 = MagneticSensorPWM(2, 4, 904);
MagneticSensorPWM sensor2 = MagneticSensorPWM(3, 4, 904);
Please check the magnetic_sensor_analog_pwm.ino example to see more about it.
BEWARE: Blocking support limitations โ ๏ธ
Blocking support for magnetic sensors is arguably has the worst performance out of all the position sensing techniques supported in this library. Each time the code reads the angle from the sensor it will read one pulse and since the magnetic sensor have PWM frequency of around 1kHz, it means the the shortest execution time for reading an angle is around 1ms. But in case of Arudino UNO and similar MCUs this might be the only option.
Interrupt based implementation
For reading the magnetic sensors asynchronously, in the non-blocking manner, this library proposes the interrupt based method. To enable this approach one needs to first create a simple buffering handler function:
// create the class
MagneticSensorPWM sensor = MagneticSensorPWM(3, 4, 904);
// create teh buffering function
void doPWM(){sensor.handlePWM();}
And then, in the setup function, user needs to call init() funciton and afterwards call the attachInterrupt function with the buffering function in the argument. Here is an example code:
// create the class
// init the sensor
// enable the interrupt and start reading the sensor
sensor.enableInterrupt(doPWM);
And here is an example code for two sensors:
void doPWM1(){sensor1.handlePWM();}
void doPWM2(){sensor2.handlePWM();}
sensor1.enableInterrupt(doPWM1);
sensor2.enableInterrupt(doPWM2);
Make sure to look into the examples magnetic_sensor_pwm and magnetic_sensor_pwm_software_interrupt for an example of using software interrupts if you run out of hardware interrupt pins.
To use the ensor with the FOC algorithm implemented in this library, once when you have initialized sensor.init() (and possibly started the interrupts) you just need to link it to the motor by executing:
class MagneticSensorPWM{
Here is a quick example for AS5048A magnetic sensor using itโs pwm output:
// MagneticSensorPWM(uint8_t _pinPWM, int _min, int _max)
// comment out to use sensor in blocking (non-interrupt) way
