Analog output Magnetic sensor setup
In order to use your Analog output magnetic position sensor with SimpleFOClibrary first create an instance of the MagneticSensorAnalog class:
// MagneticSensorAnalog(uint8_t _pinAnalog, int _min, int _max)
// pinAnalog - the pin that is reading the analog output from magnetic sensor
// min_raw_count - the smallest expected reading.
// max_raw_count - the largest value read.
MagneticSensorAnalog sensor = MagneticSensorAnalog(A1, 14, 1020);
pinAnalog- the pin that is reading the analog output from magnetic sensor ,min_raw_count- the smallest expected reading. Whilst you might expect it to be 0 it is often ~15. Getting this wrong results in a small click once per revolutionmax_raw_count- the largest value read. Whilst you might expect it to be 2^10 = 1023 it is often ~ 1020. Note: For ESP32 (with 12bit ADC the value will be nearer 4096)
💡 Find out min and max
Every mcu is a bit different and every sensor as well so we advise you to use the provided example in theexamples/sensor_test/magentic_sensor_analog_example/find_raw_min_maxto find out the maximal and minimal values of your sensor.
Finally after the initialization the only thing you need to do afterwards is to call the init() function. This function initializes the sensor hardware. So your magnetic sensor initialization code will look like:
If you wish to use more than one magnetic sensor, make sure you connect their ADC pins to different arduino pins and follow the same idea as above, here is a simple example:
MagneticSensorAnalog sensor1 = MagneticSensorAnalog(A1, 14, 1020);
MagneticSensorAnalog sensor2 = MagneticSensorAnalog(A2, 14, 1020);
Please check the magnetic_sensor_analog_example.ino example to see more about it.
class MagneticSensorAnalog{
Here is a quick example for AS5600 magnetic sensor using it’s analog output:
