Teensy support
MCU2 PWM mode4PWM mode3 PWM mode6 PWM modepwm frequency config
teensy✔️✔️✔️❌✔️
Arduino SimpleFOClibrary has recently started to support Teensy boards as well. The most commonly tested boards are Teensy 4.1 and Teensy 3.2, but most of the boards in 4.x and 3.x series should work out of the box with the library.
BoardNameSpecificationsLinkPrice
Teensy 4.1ARM Cortex-M7
- 3.3V logic
- 35 PWMs
- 18 analog input
- 600 MHz
pjrc.com25€
Teensy 3.2ARM Cortex-M4
- 3.3V logic
- 12 PWMs
- 21 analog input
- 72 MHz
pjrc.com20€
If you are having issues with your teensy board or if you are interested in extending the support please do not hesitate to post on out community forum!
Arduino IDE support package
In order to use the Teensy boards in the Arduino IDE please instal the Teensy support package by following the steps of installing Teensyduino addon.
