Position control example
using SimpleFOCShield
For a bit more in depth explanation of Arduino UNO and SimpleFOCShield connection please check the connection examples.
For more information about the SimpleFOCShield check the docs.
Small motivation :D
Encoder code
// define Encoder
Motor code
First we need to define the BLDCMotor class with the number od pole pairs (11)
// define BLDC motor
Next we need to define the BLDCDriver3PWM class with the PWM pin numbers of the motor and the driver enable pin
// define BLDC driver
// power supply voltage
// default 12V
// MotionControlType::torque
// MotionControlType::angle
// default P=0.5 I = 10
// default value is 300 volts per sec  ~ 0.3V per millisecond
motor.voltage_limit = 6;
// angle P controller
// default P=20
//  maximal velocity of the position control
// default 20
motor.velocity_limit = 4;
// iterative FOC function
motor.move(target_angle);
Full Arduino code
To the full code I have added a small serial commander interface, to be able to change position/angle target value in real time.
// init BLDC motor
// init driver
//  init encoder
// angle set point variable
float target_angle = 0;
void onTarget(char* cmd){ command.scalar(&target_angle, cmd); }
  // default 12V
  // default P=20
  // default 20
  command.add('T', doTarget, "target angle");
  // function calculating the outer position loop and setting the target position
