Motion control
SimpleFOClibrary has two main parameters that define the motion control architecture to be used (and each of them can be modified in real-time):
- Torque control mode -
motor.torque_controller - Motion control mode -
motor.controller- Closed-loop motion control - with position sensor
- Open-loop motion control - no position sensor
Torque control modes
There are three torque control types implemented in the SimpleFOClibrary:
- Voltage -
TorqueControlType::voltage - DC current -
TorqueControlType::dc_current - FOC current -
TorqueControlType::foc_current
⚠️ This parameter is not used if the open-loop motion control is chosen.
And they can be set by changing the motor attribute torque_controller.
// set torque mode to be used
// TorqueControlType::voltage ( default )
// TorqueControlType::dc_current
// TorqueControlType::foc_current
For more in depth explanations about different torque modes visit the torque mode docs
Motion control modes
SimpleFOClibrary implements motion control for both cases:
There are three closed-loop motion control types implemented in the SimpleFOClibrary:
- Torque -
MotionControlType::torque - Velocity -
MotionControlType::velocity - Angle -
MotionControlType::angle
And they can be set by changing motor’s controller parameter.
// MotionControlType::torque
// MotionControlType::angle
For more in depth explanations about different closed-loop motion control loops visit the closed-loop control docs
Additionally you can run the motor in the open-loop, without position sensor feedback, as well:
- velocity open-loop control -
MotionControlType::velocity_openloop - position open-loop control -
MotionControlType::angle_openloop
Index search uses also uses open-loop position control, but has some additional parameters, see index search
And they too can be enabled by setting motor’s controller parameter.
// MotionControlType::velocity_openloop - velocity open-loop control
// MotionControlType::angle_openloop - position open-loop control
For more in depth explanations about different closed-loop motion control loops visit the open-loop control docs
