Torque control using FOC currents
This torque control mode allows you to the true torque control of a BLDC motor and it requires current sensing in order to do it. The user sets the target current Id to the FOC algorithm calculates the necessary phase voltages ua ,ub and uc in order to maintain it by measuring the phase currents (ia, ib and ic) and the rotor angle a. This mode is enabled by:
// FOC current torque control mode
How does it work exactly
The FOC current torque control algorithm reads the phase currents of the BLDC motor (usually ia and ib). Furthermore the algorithm reads the rotor angle a from the position sensor. The phase currents are transformed into the d current id and q current iq using the Inverse Clarke and Park transform. Using the target current value Id and the measured currents iq and id, the PID controllers for each axis calculate the appropriate voltages Uq and Ud to be set to the motor, to maintain iq=Id and id=0. Finally using Park+Clarke (or SpaceVector) transformation the FOC algorithm sets the appropriate ua, ub and uc voltages to the motor. By measuring the phase currents this torque control algorithm ensures that these voltages generate the appropriate currents and magnetic force in the motor rotor with exactly 90 degree offset from its permanent magnetic field, which guarantees maximal torque, this is called commutation.
The torque generated in the motor is proportional to the q-axis current iq, making this torque control mode the true torque control of a BLDC motor.
Configuration parameters
In order to make this loop run smoothly the user needs to configure the PID controller parameters of teh PID_current_q and Low pass filter LPF_current_q time constant.
// Q axis
// PID parameters - default
motor.PID_current_q.P = 5;                       // 3    - Arduino UNO/MEGA
motor.PID_current_q.I = 1000;                    // 300  - Arduino UNO/MEGA
motor.PID_current_q.D = 0;
motor.PID_current_q.ramp = 1e6;                  // 1000 - Arduino UNO/MEGA
// Low pass filtering - default
LPF_current_q.Tf= 0.005;                         // 0.01 - Arduino UNO/MEGA
// D axis
motor.PID_current_d.P = 5;                       // 3    - Arduino UNO/MEGA
motor.PID_current_d.I = 1000;                    // 300  - Arduino UNO/MEGA
motor.PID_current_d.D = 0;
motor.PID_current_d.limit = motor.voltage_limit;
motor.PID_current_d.ramp = 1e6;                  // 1000 - Arduino UNO/MEGA
LPF_current_d.Tf= 0.005;                         // 0.01 - Arduino UNO/MEGA
Torque control example code
A simple example of the FOC current based torque control using Inline current sensor and setting the target value by serial command interface.
// current sensor
void doTarget(char* cmd) { command.variable(&motor.target, cmd); }
  // set torque mode:
  // foc current control parameters (Arduino UNO/Mega)
  motor.PID_current_q.I= 300;
  motor.PID_current_d.P= 5;
  motor.PID_current_d.I = 300;
  motor.LPF_current_d.Tf = 0.01;
