Stepper motor control example
using L298N and Stm32 Nucleo-64
For this stepper motor control example we are going to be using this hardware:
Here is an example of the connection scheme using the L298N and Nucleo-64:
L298N
  • Channels ENA and ENB are connected to pins 7 and 8
  • Channels IN1, IN2, IN3 and IN4 are connected to the pins 5, 6, 9, 10
  • Common ground is connected in between nucleo and L298N
  • 12V power-supply is connected directly to the driver
  • Channels A and B are connected to the pins A0 qnd A1
  • Index channel is not used in this example but you cqn easily modify this example to support it
  • Motor phases A1, A2, B1and B2 are connected directly the motor connectors of the L298N chip.
Full Arduino code
// Stepper motor instance
StepperMotor motor = StepperMotor(50);
// Stepper driver instance
StepperDriver4PWM driver = StepperDriver4PWM(5, 6, 9, 10,  8, 7);
Encoder encoder = Encoder(A1, A2, 2048);
  // choose FOC modulation
  motor.PID_velocity.D = 0;
  motor.voltage_limit = 12;
  // angle loop controller
  // angle loop velocity limit
  motor.velocity_limit = 50;
  motor.target = 2;
  // define the motor id
  // if tatget not set in parameter uses motor.target variable
