Stm32 Bluepill using the Arduino SimpleFOCShield
The SimpleFOCShield, being a BLDC driver, can be used not just with boards with Arduino UNO headers but also as a stand alone driver board.
Here is an example how to connect Stm32 Bluepill with the Arduino SimpleFOCShield :
More information about the Arduino Simple FOC Shield.
Bluepill pinout
Make sure to consult the pinout before you assign the BLDC driver pins. They have to be PWM capable.
- Channels
AandBare connected toPB9andPB8. - If your encoder has
indexsignal you can connect it to the boards as well, for example onPB7.
NOTE
Any digital pin can be external interrupt pin on STM32 boards.
SimpleFOCShield connection
- Connect
PWMa,PWMbandPWMcsignal toPA10,PA9andPA8of the Bluepill. - Connect the
enablepin to any digital pin such asPA11 - Connect the common ground
GND - Connect the power-supply cable
Example connection
