Torque control loop
SimpleFOClibrary gives you the choice of using 3 different torque control strategies:
- Voltage mode -
voltage - DC current mode -
dc_current - FOC current mode -
foc_current
In short voltage control mode is the simplest approximation of the motor torque control and it so basic that can be run on any motor+driver+mcu combination out there. DC current mode is teh next step of the motor’s torque approximation which is much more exact than the voltage mode but requires current sensing and much stronger microcontroller. FOC current mode is controls motor’s true torque and it is not an approximation, it also requires current sensor and even more processing power than the DC current mode. See in depth explanations in torque mode docs.
This motion control mode is enabled setting the controller parameter to:
// torque control loop
If the voltage control mode is used and if the user does not provide the phase resistance parameter to the motor, the input to the torque control loop will be the target voltage Uq:
And if one of the current based torque control modes (DC current or FOC current) is used, the input in the control loop will be the target current iq. The same is true in the voltage mode if the user provides the phase resistance value to the motor class.
The torque control loop is used as a base for all other motion control loops. For more info about the content of the blue boxes check the torque mode docs.
Configuration parameters
Depending on the torque control type you wish to use there are different parameters that you need to consider.
- Voltage mode - the simplest one - no parameters except maybe
motor.phase_resistance - DC current mode - 1xPID controller + 1xLPF
- FOC current mode - 2xPID controller + 2xLPF filters
Now, lets see one example!
Voltage control example
You can test this algorithm by running the example voltage_control.ino.
Here we provide an example of a toque using voltage control program with full motion control configuration. The program sets target Uq voltage of 2V to the motor using the FOC algorithm. Since the phase resistance parameter is not available the motor target will be in volts.
// set the torque control type
Serial.println(F("Target voltage is 2V"));
motor.move(2);
If we add the pahse resitance to the constructor of the BLDCMotor class, the motor target will be in Amps.
BLDCMotor motor = BLDCMotor(11, 12.34); // 12.34 Ohms
Serial.println(F("Target current is 0.5Amps"));
motor.move(0.5);
Project examples
Here is one very cool project example which uses torque control and describes the full hardware + software setup needed.
