Velocity open-loop control
This control loop allows you to spin your BLDC motor with desired velocity without using position sensor. This mode is enabled by:
// set velocity control open-loop mode
You can test this algorithm by running the examples in motion_control/openloop_motor_control/ folder.
This control algorithm is very simple. User can set the target velocity it wants to achieve vd, the algorithm is going to integrate it in time to find out what is the angle it needs to set to the motor ac in order to achieve it. Then the maximal allowed voltage motor.voltage_limit is going to be applied in the direction of the ac using SinePWM or SpaceVectorPWM modulation.
This is the simplified version of the calculation of the next angle to set to the motor:
next_angle = past_angle + target_velocity*d_time;
You need to know the target_velocity, sample time d_time and past value of the angle past_angle you have set to the motor.
Configuration
// choose FOC modulation (optional) - default SinePWM
// limiting voltage
motor.voltage_limit = 3; // Volts
// or current - if phase resistance provided
motor.current_limit = 0.5 // Amps
This type of motion control is highly inefficient therefore try not to use to high value for motor.voltage_limit. We suggest you to provide the motor class with the phase_resistance value and set the motor.current_limit instead the voltage limit. This current might be surpassed but at least you will know an approximate current your motor is drawing. You can calculate the current the motor is going to be producing by checking the motor resistance phase_resistance and evaluating:
voltage_limit = current_limit * phase_resistance; // Amps
Also, you can change the voltage/current limit in real-time if you need this kind of behavior in your application.
Velocity open-loop control example
Here is one basic example of the velocity open-loop control with the complete configuration. The program will set the target velocity of 2 RAD/s and maintain it, and the user cna change the target velocity using serial terminal.
// BLDCMotor( pp number , phase resistance)
BLDCMotor motor = BLDCMotor(11 , 12.5);
//target variable
float target_velocity = 2; // rad/s
void doTarget(char* cmd) { command.variable(&target_velocity, cmd); }
// limiting motor current (provided resistance)
motor.current_limit = 0.5; // [Amps]
// open loop control config
// init motor hardware
// using motor.current_limit and motor.velocity_limit
motor.move(target_velocity);
