Index search routine
Finding the encoder index is performed only if the constructor of the Encoder class has been provided with the index pin. The search is performed by setting a constant velocity of the motor until it reaches the index pin. To set the desired searching velocity alter the parameter:
// index search velocity - default 1rad/s
motor.velocity_index_search = 2;
The index search is executed in the motor.initFOC() function.
This velocity control loop is implemented exactly the same as velocity open-loop and the only difference is that the voltage set to the motor will not be the motor.volatge_limit (or motor.curren_limit*motor.phase_resistance) but motor.voltage_sensor_align.
Example of code using Index search
This is an example of a motion control program which uses encoder as position sensor and particularly, encoder with index signal. The index search velocity is set to be 3 RAD/s:
// index search velocity [rad/s]
motor.velocity_index_search = 3;
After the motor and the position senor have been aligned in motor.initFOC() by performing index search. The motor will start spinning with angular velocity 2 RAD/s and maintain this value.
// motor instance
// driver instance
Encoder encoder = Encoder(2, 3, 500, A0);
void doIndex(){encoder.handleIndex();}
encoder.enableInterrupts(doA, doB,doIndex);
motor.velocity_index_search = 3; // rad/s
motor.voltage_sensor_align = 4; // Volts
// controller configuration
// default parameters in defaults.h
motor.voltage_limit = 6;
// default value is 300 volts per sec ~ 0.3V per millisecond
// angle set point variable
float target_velocity = 2;
motor.move(target_velocity);
