Position control example
using SimpleFOCShield and Stm32 Nucleo-64
For a bit more in depth explanation of how to connect Nucleo board and SimpleFOCShield connection please check the connection examples.
For more information about the SimpleFOCShield check the docs.
- Channels
AandBare connected to the encoder connectorP_ENC, terminalsAandB. - Index channel you can connect directly to the
P_ENCas well to the terminalIMotor
Encoder code
// define Encoder
Encoder encoder = Encoder(A1, A2, 2048, A0);
// channel A, B and index callbacks
void doI(){encoder.handleIndex();}
encoder.enableInterrupts(doA, doB, doI);
For more configuration parameters of the encoders please check the Encoder class docs.Motor code
First we need to define the BLDCMotor class with the number od pole pairs (11)
// define BLDC motor
If you are not sure what your pole pairs number is please check the find_pole_pairs.ino example.Next we need to define the BLDCDriver3PWM class with the PWM pin numbers of the motor and the driver enable pin
// define BLDC driver
// power supply voltage
// default 12V
```oltage_power_supply = 12;
Next thing we can change is the index search velocity:
// index search velocity
// default 1 rad/s
motor.velocity_index_search = 3;
// MotionControlType::torque
// MotionControlType::angle
// default P=0.5 I = 10
// angle P controller
// default P=20
// default 20
motor.velocity_limit = 20;
// initial target value
motor.target = 0;
// iterative FOC function
That is it, that is the full code for the motor, FOC and motion control initialization and configuration. Let’s enable user communication now.
For more configuration parameters and control loops please check the BLDCMotor class doc.Monitor motor init
In order to enable it we need to enable monitoring before the call of the motor.init() and motor.initFOC():
// enable monitoring functionality
User communication
At the end the Arduino SimpleFOClibrary enables you to change all the configuration parameters in real-time as well as read the motor state variables, and set the target values by using commander interface.
First we instantiate the commander class:
Then we create the wrapper for generic motor callback:
We subscribe the new command callback:
And we add the commander runtime function the Arduino loop:
And that is it, we everything configured and ready to go, let’s see the full code!
For more info about the monitoring and motor commands visit the Writing the Code section.
Full Arduino code
// init BLDC motor
// init driver
// init encoder
// default 12V
// default 1 rad/s
// default value is 300 volts per sec ~ 0.3V per millisecond
// default P=20
// default 20
// initial angle target
// it will be changed by the commander class
motor.target = 0;
// define the motor id
// position motion control loop
