Stepper motor control example
using L298N and Stm32 Nucleo-64
For this stepper motor control example we are going to be using this hardware:
Here is an example of the connection scheme using the L298N and Nucleo-64:
L298N
- Channels
ENAandENBare connected to pins7and8 - Channels
IN1,IN2,IN3andIN4are connected to the pins5,6,9,10 - Common ground is connected in between nucleo and L298N
- 12V power-supply is connected directly to the driver
- Channels
AandBare connected to the pinsA0qndA1 - Index channel is not used in this example but you cqn easily modify this example to support it
A1,A2,B1andB2are connected directly the motor connectors of the L298N chip.
Full Arduino code
// Stepper motor instance
StepperMotor motor = StepperMotor(50);
// Stepper driver instance
StepperDriver4PWM driver = StepperDriver4PWM(5, 6, 9, 10, 8, 7);
Encoder encoder = Encoder(A1, A2, 2048);
// choose FOC modulation
motor.PID_velocity.D = 0;
motor.voltage_limit = 12;
// angle loop controller
// angle loop velocity limit
motor.velocity_limit = 50;
motor.target = 2;
// define the motor id
// if tatget not set in parameter uses motor.target variable
