Motion control
SimpleFOClibrary gives you the choice of using 3 different closed-loop motion control strategies:
You set it by changing the motor.controller variable. If you want to control the motor angle you will set the controller to MotionControlType::angle, if you seek the torque of the BLDC motor either through voltage or the current use MotionControlType::torque, if you wish to control motor angular velocity MotionControlType::velocity.
// set FOC loop to be used
// MotionControlType::torque
// MotionControlType::angle
