Extending commander with custom functionality
To extend the commander interface with your own functionality that has not been implemented by the SimpleFOClibrary you only really need to:
- implement your callback function
void myFunc(char*){} - add it to the commander
commander.add('.',myFunc,"..")
void myFunc(char*){
// do something useful
Commander commander = Commander(...)
commander.add('A',myFunc,"my functionality");
commander.run()
Example
This is an example code of extending the commander interface with two new functionalities, turning on and off a led light and reading 5 analog pins.
// led control function
void doLed(char* cmd){
if(atoi(cmd)) digitalWrite(LED_BUILTIN, HIGH);
else digitalWrite(LED_BUILTIN, LOW);
// get analog input
void doAnalog(char* cmd){
if (cmd[0] == '0') Serial.println(analogRead(A0));
else if (cmd[0] == '1') Serial.println(analogRead(A1));
else if (cmd[0] == '2') Serial.println(analogRead(A2));
else if (cmd[0] == '3') Serial.println(analogRead(A3));
else if (cmd[0] == '4') Serial.println(analogRead(A4));
// define pins
pinMode(LED_BUILTIN, OUTPUT);
pinMode(A0, INPUT);
pinMode(A1, INPUT);
pinMode(A2, INPUT);
pinMode(A3, INPUT);
pinMode(A4, INPUT);
// Serial port to be used
// add new commands
command.add('L', doLed, "led on/off");
command.add('A', doAnalog, "analog read A0-A4");
Serial.println(F("Commander listening"));
Serial.println(F(" - Send ? to see the node list..."));
Serial.println(F(" - Send L0 to turn the led off and L1 to turn it off"));
Serial.println(F(" - Send A0-A4 to read the analog pins"));
_delay(10);
Then in your serial terminal you can just
$ ? # list the commands
L: led on/off
A: analog read A0-A4
$ L0 # led off
$ A1 # read A1
321
$ A3 # read A3
1023
$ L1 # led on
$ L0 # led off
