Arduino SimpleFOClibrary source code v2.1
The arduino library code is organized into the standard Arduino library structure. The library contains FOC implementation for two types of BLDC motors, standard three phase BLDC motor in the class BLDCMotor and 2 phase stepper motors StepperMotor. The library implements numerous position sensors and they are all placed in the senors directory as well as drivers which are in the drivers directory. The library implements current sensors as well and they are placed in the current_sense directory as well as several communication interfaces, placed in the communication folder. Finally all the utility functions and classes are placed in the common folder.
Arduino library source structure
| src
| ├─ SimpleFOC.h # Main include file
| ├─ BLDCMotor.cpp/h # BLDC motor handling class
| ├─ StepperMotor.cpp/h # Stepper motor handling class
│ ├─── common # Contains all the common utility classes and functions
| ├─── drivers # PWM setting and driver handling specific code
| ├─── sensors # Position sensor specific code
| ├─── current_sense # Current sense implementations
| ├─── communication # Communication protocols implementation
For more info visit full source code documentation
Motors
BLDCMotor.cpp/h
BLDCMotor class implementation
- FOC algorithm implementation
- Motion control implementation
StepperMotor.cpp/h
FOC implementation details - Documentation of the procedures and detailed explanations of the code implementing FOC algorithm
Motion control implementation details - Documentation of the motion control algorithms and code implementation choices
Drivers
All the drivers that are supported in this library are placed in the drivers directory.
| ├─── drivers
| | ├─ BLDCDriver3PWM.cpp/h # Implementation of generic 3PWM bldc driver
| | ├─ BLDCDriver6PWM.cpp/h # Implementation of generic 6PWM bldc driver
| | ├─ StepperDriver2PWM.cpp/h # Implementation of generic 2PWM stepper driver
| | ├─ StepperDriver4PWM.cpp/h # Implementation of generic 4PWM stepper driver
| | ├─ hardware_api.h # common mcu specific api handling pwm setting and configuration
| | ├─── hardware_specific # mcu specific hadrware_api.h implementations
| | | ├─ atmega2560_mcu.cpp # ATMega 2560 implementation
| | | ├─ atmega328_mcu.cpp # ATMega 328 (Arduino UNO) implementation
| | | ├─ esp_mcu.cpp # esp32 implementation
| | | ├─ stm32_mcu.cpp # stm32 implementation
| | | ├─ teensy_mcu.cpp # teensy implementation
| | | └─ generic_mcu./h # generic implementation - if not nay of above (not complete)
ALl BLDC drivers implement the abstract class BLDCDriver.
class BLDCDriver{
/** Initialise hardware */
virtual int init();
/** Enable hardware */
virtual void enable();
/** Disable hardware */
virtual void disable();
long pwm_frequency; //!< pwm frequency value in hertz
float voltage_power_supply; //!< power supply voltage
float voltage_limit; //!< limiting voltage set to the motor
//Set phase voltages to the hardware
// @param Ua - phase A voltage
// @param Ub - phase B voltage
// @param Uc - phase C voltage
virtual void setPwm(float Ua, float Ub, float Uc);
// Set phase state, enable/disable
// @param sc - phase A state : active / disabled ( high impedance )
// @param sb - phase B state : active / disabled ( high impedance )
// @param sa - phase C state : active / disabled ( high impedance )
virtual void setPhaseState(int sa, int sb, int sc) = 0;
And all the stepper drivers implement the StepperDriver abstract class.
class StepperDriver{
virtual int init();
* Set phase voltages to the hardware
* @param Ua phase A voltage
* @param Ub phase B voltage
virtual void setPwm(float Ua, float Ub);
Furthermore all the supported MCU architectures with the simplefoc library have to implement the header file hardware_api.h. The off-the-shelf supported architectures will have implementation of the hardware_api.h placed in the hardware_specific folder. If you wish to implement a new MCU please do create a new instance of the my_new_mcu.cpp and implement all the functions from the hardware_api.h, or at least the ones that you need.
Sensors
| ├─── sensors
| │ ├─ Encoder.cpp/h # Encoder class implementing the Quadrature encoder operations
| │ ├─ MagneticSensorSPI.cpp/h # class implementing SPI communication for Magnetic sensors
| │ ├─ MagneticSensorI2C.cpp/h # class implementing I2C communication for Magnetic sensors
| │ ├─ MagneticSensorAnalog.cpp/h # class implementing Analog output for Magnetic sensors
└─ HallSensor.cpp/h # class implementing Hall sensor
All position sensor classes implemented in this library are placed in this directory, and all of them will be implementing abstract sensor class Sensor. Every sensor needs to implement the Sensor class in order to be linkable to the motor (BLDCMotor and StepperMotor class). If you want to implement your own version of the sensor, jut extend this class and implement the virtual functions and you will be able to run the FOC algorithm with it. You will be abele to link motor and the sensor by doing motor.linkSensor(your sensor)
class Sensor{
// get current angle (rad)
virtual float getAngle() = 0;
// get current angular velocity (rad/s)
// initially implemented - can be overridden
virtual float getVelocity();
// returns 0 if it does need search for absolute zero
// 1 - encoder with index (with index not found yet)
// 0 - everything else (& encoder with index which is found)
// initially implemented by default returns 0
virtual int needsSearch();
Current Sense
| ├─── current_sense
| │ ├─ InlineCurrentSense.cpp/h # Inline current sensor implementation
| | ├─ hardware_api.h # common mcu specific api handling adc setting and configuration
| | └─ generic_mcu./h # generic implementation - for now generic mcu does the job
All the current sense classes implement the CurrentSense interface. This interface is still quiet new and might be supject to change for the future releases when more current control loops are implemented.
class CurrentSense{
// Function intialising the CurrentSense class
// All the necessary intialisations of adc and sync should be implemented here
virtual void init() = 0;
// Function reading the phase currents a, b and c
// This function will be used with the foc control through the function
// CurrentSense::getFOCCurrents(electrical_angle)
// - it returns current c equal to 0 if only two phase measurements available
// @return PhaseCurrent_s current values
virtual PhaseCurrent_s getPhaseCurrents() = 0;
// Function reading the magnitude of the current set to the motor
// It returns the abosolute or signed magnitude if possible
// It can receive the motor electrical angle to help with calculation
// This function is used with the current control (not foc)
// @param angle_el - electrical angle of the motor (optional)
virtual float getDCCurrent(float angle_el = 0);
// Function used for FOC contorl, it reads the DQ currents of the motor
// It uses the function getPhaseCurrents internally
// @param angle_el - motor electrical angle
DQCurrent_s getFOCCurrents(float angle_el);
// driver sync and align functions
//Function intended to implement all that is needed to sync and current sensing with the driver.
// If no such thing is needed it can be left empty (return 1)
// @returns - 0 - for failure & 1 - for success
virtual int driverSync(BLDCDriver *driver) = 0;
//Function intended to verify if:
// - phase current are oriented properly
// - if their order is the same as driver phases
// This function corrects the alignment errors if possible ans if no such thing is needed it can be left empty (return 1)
// @returns - 0 - for failure & positive number (with status) - for success
virtual int driverAlign(BLDCDriver *driver, float voltage) = 0;
bool skip_align = false; //!< variable signaling that the phase current direction should be verified during initFOC()
Communication
| ├─── communication
| │ ├─ Communicator.cpp/h # Commander communication interface implementation
| │ ├─ commands.h # Command list definition
| │ └─ StepDirListener.cpp/h # Step/dir listener implementation
This folder contains all the built-in supported communication protocols.
Commander.cpp/h
Commander class implements
- Flexible g-code like communication
- Handling of serial communication
- Built-in handling of
FOCMotor,PIDControllerandLowPassFilterclasses - much more…
Commander functionality - Documentation of the commander class
Commands list - Documentation of the motor commands functionality
StepDirListener class implements
- A simple implementation of the step+dir communication protocol
Step/direction listener functionality - Documentation of the step dir listener class
Common
| | ├─ defaults.h # default motion control parameters
| | ├─ foc_utils.cpp./h # utility functions of the FOC algorithm
| | ├─ time_utils.cpp/h # utility functions for dealing with time measurements and delays
| | ├─ pid.cpp./h # class implementing PID controller
| | ├─ lowpass_filter.cpp./h # class implementing Low pass filter
| | ├─── base_classes
| | | ├─ FOCMotor.cpp./h # common class for all implemented motors
| | | ├─ BLDCDriver.h # common class for all BLDC drivers
| | | ├─ StepperDriver.h # common class for all Stepper drivers
| | | └─ Sensor./h # common class for all implemented sensors
The common directory contains all the definitions and common utility functions for the SimpleFOClibrary. It contains the definitions of the abstract classes for motors, sensors and drivers in the base_classes directory. It has two libraries of utility functions for time management time_utils.cpp/h and FOC helpers foc_utils.cpp/h. Finally it has definition and implementation of the two signal processing classes: pid controller pid.cpp/h and low pass filter lowpass_filter.cpp/h. It also contains the default configuration parameters of the library in the defaults.h header file. Header file containing all the default configuration variables
// default configuration values
// change this file to optimal values for your application
#define DEF_POWER_SUPPLY 12.0 //!< default power supply voltage
// velocity PI controller params
#define DEF_PID_VEL_P 0.5 //!< default PID controller P value
#define DEF_PID_VEL_I 10 //!< default PID controller I value
#define DEF_PID_VEL_D 0 //!< default PID controller D value
#define DEF_PID_VEL_U_RAMP 1000 //!< default PID controller voltage ramp value
// angle P params
#define DEF_P_ANGLE_P 20 //!< default P controller P value
#define DEF_VEL_LIM 20 //!< angle velocity limit default
// index search
#define DEF_INDEX_SEARCH_TARGET_VELOCITY 1 //!< default index search velocity
// align voltage
#define DEF_VOLTAGE_SENSOR_ALIGN 6.0 //!< default voltage for sensor and motor zero alignemt
// low pass filter velocity
#define DEF_VEL_FILTER_Tf 0.005 //!< default velocity filter time constant
Digging deeper
For more info about the FOC procedures and detailed explanations of the code implementing FOC algorithm please visit: FOC implementation details
For documentation of the motion control algorithms and code implementation choices, visit Motion control implementation details
The library comes with a lot of motor control examples for different microcontrollers. See more on library examples
To dig deeper in the source code please visit Doxygen generated code documentation
