In-line current sensing
Inline current sensing technique is the simplest one to use and the most precise one. The shunt resistors are placed in-line with motor phases and the current measured on these shunt resistors will be motor phase current regardless of the state of the PWM duty cycle. This implementation is therefore very suitable for Arduino devices due to the fact that adc can be sampled at any time to read the current and the adc acquisition duration is as important as for the other current sensing approaches. The downside of this approach is the hardware, this current sensing architecture requirers high-precision bidirectional amplifiers with much better PWM rejection than the regular low-side or high-side amplifiers.
Step 1. Hardware configuration
// InlineCurrentSensor constructor
// - shunt_resistor - shunt resistor value
// - gain - current-sense op-amp gain
// - phA - A phase adc pin
// - phB - B phase adc pin
// - phC - C phase adc pin (optional)
InlineCurrentSense current_sense = InlineCurrentSense(0.01, 20, A0, A1, A2);
To instantiate the inline current sensor using the SimpleFOClibrary just create an instance of the class InlineCurrentSense. This class takes as a parameter shunt resistance value shunt_resistor, amplification gain gain and two or three ADC channel pins depending on the available measuring hardware that you might have. It is important to specify right adc channels for right driver/motor phase. So if your pin A0 measures the phase current A and pin A1 measures the phase current B make sure to put provide them to the constructor in that order.
Field Oriented Control algorithm can run with both 2 or 3 phase current measurements.
The constructor of the InlineCurrentSense class only allows you to specify one shunt resistor value and one amplification gain. If your hardware configuration has different shunt/amp values for different phases you can specify them by changing the gain_x attribute:
For example Arduino SimpleFOCShield v2 has the phase B of the current sensing inverted. So in its case you can specify:
// inverse current sensing gain on phase b
current_sense.gain_b *= -1;
Once the current sense has been created it can be initialised. This init() function configures the ADC hardware for reading and finds the zero offsets of the ADC for each channel.
// init current sense
Once when your current sense has been intialised and calibrated you can start measuring the currents!
To use the InlineCurrentSense with the FOC algorithm all you need to do is to add it to link it with the BLDCMotor you wish to use it with:
The BLDCMotor class in the initFOC() function where it aligns all the sensors, will align the InlineCurrentSense with the BLDCDriver that is linked to the motor.
// prepare sensors for FOC
Function initFOC() will call two current sense class functions that are important:
current_sense.driverSync(...)current_sense.driverAlign(...)
Driver synchronisation driverSync(...)
Since the Inline current sensing technique does not require triggering of particular events for ADC acquisition the driverSync() function does nothing really. This function will be very ipmportant for low-side and high-side current sensing as shown on the figure above.
Alignment with the motor phases driverAlign(...)
The alignment is done by calling the function:
current_sense.driverAlign(&driver, voltage_sensor_align);
This function applies using the driver instance applies the voltage to each of the phases and checks if the measured currents correspond to the directions of the applied voltages. This alignment procedure is able to correct for:
- Incorrect order of adc pins
- Incorrect gain sign
0- fail1- success and nothing changed2- success but pins reconfigured3- success but gains inverted4- success but pins reconfigured and gains inverted
// skip alignment procedure
For example Arduino SimpleFOCShield v2, you would have a code similar to this:
// invert phase b gain
current_sense.gain_b *=-1;
// skip alignment
// align all sensors
Standalone current sense
To use your inline current sensor as a stand-alone sensor after you have configured the hardware and calibrated it you can read the phase currents by calling:
PhaseCurrent_s current = current_sense.getPhaseCurrents();
Serial.println(current.a);
Serial.println(current.b);
If you are using only two phase current measurements in your InlineCurrentSense, it will return the third current current.c equal to 0.
Serial.println(current.d);
Serial.println(current.q);
Example code
Here is a simple example of a inline current sense as a stand-alone sensor using the SimpleFOClibrary and SimpleFOCShield v2.
// current sensor
// shunt resistor value
// gain value
// pins phase A,B
// for SimpleFOCShield v2.01/v2.0.2
Serial.println("Current sense ready.");
Serial.print(currents.c*1000); // milli Amps
Serial.println(current_magnitude*1000); // milli Amps
