Velocity control example
using Drotek’s L6234 driver
Drotek’s L6234 breakout board is a very minimalistic 3-phase BLDC motor driver and is very suitable for jump-starting your FOC experience. Here we the velocity control example project using the SimpleFOClibrary and this hardware:
For a bit more in depth explanation of Arduino UNO and L6234 connection please check the connection examples.
- Encoder channels
A
andB
are connected to the Arduino’s external interrupt pins2
and3
- Connected to the arduino pins
9
,10
and11
(you can use also pins5
and6
). - Additionally you can connect the
enable
pin to the any digital pin of the arduino the picture shows pin8
but this is optional. You can connect the driver enable directly to 5v. - Make sure you connect the common ground of the power supply and your Arduino
a
,b
andc
are connected directly to the driver outputs
Let’s go through the full code for this example and write it together. First thing you need to do is include the SimpleFOC
library:
Encoder code
First we define the Encoder
class with the A and B channel pins and number of impulses per revolution.
// define Encoder
In the setup()
function we initialize the encoder and enable interrupts:
For more configuration parameters of the encoders please check the Encoder
class docs.
Motor code
First we need to define the BLDCMotor
class with the number od pole pairs (14
// define BLDC motor
BLDCMotor motor = BLDCMotor(14);
If you are not sure what your pole pairs number is please check the find_pole_pairs.ino
example.
Next we need to define the BLDCDriver3PWM
class with the PWM pin numbers of the motor and the driver enable pin
// define BLDC driver
Then in the setup()
we configure first the voltage of the power supply if it is not 12
Volts and init the driver.
// power supply voltage
// default 12V
Then we tell the motor which control loop to run by specifying the motor.controller
variable.
// MotionControlType::torque
// MotionControlType::angle
Now we configure the PI controller parameters
// default P=0.5 I = 10
motor.voltage_limit = 6;
For more information about the velocity control loop parameters please check the doc.
And finally we connect the encoder and the driver to the motor, do the hardware init and init of the Field Oriented Control.
The last peace of code important for the motor is of course the FOC routine in the loop
function.
// iterative FOC function
// iterative function setting and calculating the velocity loop
motor.move(target_velocity);
For more configuration parameters and control loops please check the BLDCMotor
class doc.
Full Arduino code
To the full code I have added a small serial commander interface, to be able to change velocity target value in real time.
BLDCMotor motor = BLDCMotor( 14 );
// define Encoder
// velocity set point variable
float target_velocity = 0;
void onTarget(char* cmd){ command.scalar(&target_velocity, cmd); }
// default 12V
Serial.println("Set the target velocity using serial terminal:");
// iterative foc function
